evenin you phat whorebags!!
laptop died...quote to fix $2500!!! just got a new one, this windows vista sucks ass... took forever to get my wireless going lol . still i'm happy i did it myself, gotta ring up the it geek people i had booked to come out tomorrow and tell them they're not needed :)
also, teh zac needs to decide by tomorrow if he is moving to buderim or rockhampton..
rocky would be way cheaper to live and i will get a juicy promotion out of it if i go for a 12month contract up there... but buderim has a better climate and is closer to brisvagas :) but will cost more to live there and the lab probably isn't as fun to work in as rocky's one :)
yeah true...
and col i should have spoke to you about my laptop! i went to harvey norman at everton park (i think) on south pine road (also i think...) and first they sold me a computer that had already been opened and resealed- got it home and had no power supply and the laptop was already in standby..then swapped it for a new one, got it home and the surge protector blew up within 30min of using it lol
yeah true...
thats pretty bad..specs of your new lappy??
yeah true...
Yeah you should have given me a buzz...
I could have hooked you up...
Everton Park is one of my stores too...
hehe.. poor matt had to slave away for 2 hours in poor lighting to get it installed, but it is up and running :) hope you havent drank too many more of those beers already or this thread is likely to get crazy pretty fast. pm me your msn if u like :)
thanks again
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
