I think you'd find it ok with any of those cars as their power band is so late that you'd just have to control the car on boost.....tight lsd's would make them predictable and they'd mostly just spin the wheels through the gears and leave tough lines :) Traction would be non existant....but in real terms you wouldn't be running a "race tune" all the time. You'd have a street tune with lower boost and lower fuel usage so you didn't foul the plugs 24/7 and need to stop off at the fuel station every 20k's.
I think you'd find it ok with any of those cars as their power band is so late that you'd just have to control the car on boost.....tight lsd's would make them predictable and they'd mostly just spin the wheels through the gears and leave tough lines :) Traction would be non existant....but in real terms you would have a street tune with lower boost and lower fuel usage so you didn't foul the plugs 24/7 and didn't need to stop off at the fuel station every 20k's.
So what you are saying is these guys "can" make 1000 ponies but their street setup is more like 6 or 700, hmmm. Give me the gtr any day.
I have finally got my car going again. It was the bloody spark plugs.,Fouled up real bad.
Im glad it wasnt to serious.
good to hear...your car must be overfueling pretty bad to cause them to foul to the point of the car not even starting or attempting to start....
Yeah thats the mircotech for you. They were iridiums only 12000kms old $120 bucks. I will stick to the coppers for $20 a change better in the pocket.
lol this is a great example of why u shoudlnt run dear plugs, as they foul soo easily!
I was told the plugs they sold me were the wrong ones anyway so what ever you do dont get the BKR5EIX-11 wrong heat range and gap.
Well it is for my car.
The recommended ones are the BCPR6ES all ready comes with 0.8 gap.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
