you'll get over your inferiority issues one day john
also, i might be able to help with the x-trails. after all, we do buy them from nissan too ;)
then you need to get out of your parents house more and stop looking on the internet
:D
here are a few groupie photos, more to come lee
Lol, dude i have heaps of random pics of Chicks too....
They only let you take their photos cos they think your a gay hair dresser and dont want to root them, they know if i took their photos i would be sexen them all night lokng :)
its a very big tune lee. the car was only running 6psi before that and now we are connecting up the intercooler as well, so no i am not deluded, i actually know what i'm on about.
They only let you take their photos cos they think your a gay hair dresser and dont want to root them, they know if i took their photos i would be sexen them all night lokng :D
NO! NO! NO! Lee. didnt you notice that hlaf the groupys were male. Just confirms what we always suspected about rotorheads.
dude, pics you downloaded off the net dont count, seriously. and since when is Lihn letting you out of your cage at night? i heard you got in trouble down at the animal pound last time you got let out? something about violating the strays? :)
this coming from a man saying his the turbo on his car doesn't run a wastegate.....
i'm really sure you do, thats why your doing all the work your self... oh wait your not :D
dude 130 to 250 is almost double your figure... so what now your running 30psi???
actually i dont think its that hard to get 200+kw out of a 13BT, only problem is he'll have 0.000000000001nm of torque :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
