you'll get over your inferiority issues one day john
also, i might be able to help with the x-trails. after all, we do buy them from nissan too ;)
then you need to get out of your parents house more and stop looking on the internet
:D
here are a few groupie photos, more to come lee
Lol, dude i have heaps of random pics of Chicks too....
They only let you take their photos cos they think your a gay hair dresser and dont want to root them, they know if i took their photos i would be sexen them all night lokng :)
its a very big tune lee. the car was only running 6psi before that and now we are connecting up the intercooler as well, so no i am not deluded, i actually know what i'm on about.
They only let you take their photos cos they think your a gay hair dresser and dont want to root them, they know if i took their photos i would be sexen them all night lokng :D
NO! NO! NO! Lee. didnt you notice that hlaf the groupys were male. Just confirms what we always suspected about rotorheads.
dude, pics you downloaded off the net dont count, seriously. and since when is Lihn letting you out of your cage at night? i heard you got in trouble down at the animal pound last time you got let out? something about violating the strays? :)
this coming from a man saying his the turbo on his car doesn't run a wastegate.....
i'm really sure you do, thats why your doing all the work your self... oh wait your not :D
dude 130 to 250 is almost double your figure... so what now your running 30psi???
actually i dont think its that hard to get 200+kw out of a 13BT, only problem is he'll have 0.000000000001nm of torque :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
