:lol:
"he no know wot he know about ereting"
Got to admit, he's pretty harcore. He "racers with racer friends" and runs 11psi everyday..his car is "hard tuned" and he "love gtr..just not everyday"....
He better be running a t78 with all that boost... 11 psi is hardcore... and hard tuned with stock internals, holy shit!
No shit, he obviously goes to the secret spots where it's 2g buy in winner takes all...he is, after all, much richer than all of us. Keep this quiet but I think he has a stand alone fuel management system.....and maybe two of the big ones...
You dont even need to go hardcore, you can just put on a turbo back exhaust and pod filter and get probably 11psi... :happy:
NO WAY SMOOTH!!! You're saying I got a 3037s, cams, greddy plenum, bigger injectors etc all for nothing?? SHIT!! I thought i needed all that stuff to run 11psi!!!! Damn...I should have got Series II to give me advice.
Hey, would a r33 making 220 RWKW on 12.5psi on standard turbo sound flogged or realistic
extremely unlikely, unless the dyno was set up to read incorrectly
Howdy all
Speaking of steak dinner is posted for next week :blink:
good, finally some steak!!!!!!!! :happy:
He's an amazingly big tool...
agreed :happy:
:happy:
farking gold :happy:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
