nah screw you guys. i aint takin no hooked from ipswitch....cause shane already told me they are bad news...how does he know...i dont know.
neither from the sunnycoast...cause its too far.
Edited by Oblivion
Whats with all the dodgey trading shit of late. Other sports forums i have been involved in go out of their way to root these f**kers out and get recompense. The mods in this joint only seem interested in doin whingy shit when someone has a cry cos their nose got put out of joint. >_<
no, I dont think it is working properly. As it is, it will be feeding oil to the middle gallery on the adaptor plate / block which simply cant be right - also cranking the engine hard for quite some time gets no oil preassure and the oil light stays on, then again its a bit low on oil now as I lost some in the process and have to top it up.
Ill prime all the oil lines by pouring the oil into the filter plate until it doesnt flow anymore then fill the engine up, then crank the engine and see what happens.
I'll pay for the maxi taxi up to the sunny coast, and we'll all put in for the hooker.
I'll prove your a premy
see now if you learnt to drive you wouldnt need slicks... >_<
What times were you pulling on street tyres again shane... Oh whats that, nothing, oh you cant cause your car is broken.
Oh thats right :sick:
Will we see 11s Col maybe 10s ?
Yep... 11's for sure, maby a 10 if I push it hard enough...
i just realised something...you guys want to see me.....blow my nose.....that is disgusting guys. you pieces of gheyness
Where did we mention we were going to watch. we will interview you and the hooker. hear both sides, study what was said, body language ect. Then we will know.
Oh thats right >_<
13.5 @ 107 in my 191rwkw gtst, with a 1.8s 60 footer, want me to show you the timeslip?
and whats ur best so far col? :sick:
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
