haha...I saw you in some black 32 last friday?
Yeh its a mates car, its pretty much sold though. Buying another R32 with 300rwkw++ depending on fuel and tune. We're told turbos will flow 400rwkw, plus the motor is built with 2.7lt pistons.
Should be fun
Nah, my lover Col Gtsx an I went and did lunch, like uncle bob and arntie jack
Ah yeah how are the odd couple? what you g units doin this weekend? i heard scooters are in order :sorcerer:
Arhhh my gut is spinning, that was bad McDonalds :P
What tha???
hahah, I guess they are fine. havent spoken to them in quite a while, typical moody.... uhh yeh. Scooters could be goer, minus the license thing
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
