cool how about post the list.
HKS Turbo Kit GT-SS
HKS EVC V
Sard Injectors 700cc
Sard Fuel Reg
Tomei Fuel Pump
Tomei Pon Camshafts + Pulley Set
Apexi pen turbo timer
Apexi Power FC & Hand Controller
Trust Extension Dump pipes
Trust Greddy Suction Kit
Trust Aluminium intercooler pipes
Trust Aluminium Radiator
Nismo Air Flow Meters
Nismo Engine Mount Kit
Nismo Clutch line
Nismo braided brake Lines
XFORCE 870 cfm Highflow Cat
DBA4000 Brake Rotors
Cusco Brake Stopper
Hicas lockbar
Rebuilt Calipers
C`s Short Shifter
I think thats about it....
