well the fronts had over 15degrees shane.. then it went not so sideways in the wet so i wanted to change the tops to 3.. and wolah.. i get sideways with limited ease.. yay..
the rear is something rediculous.. im gonna waste 2 rear tyres this weekend.. throw new ones on rotate and waste the fronts which will be on the rear next weekend..
haha
i hope its a typo when u say u had 15deg of camber at the front, if not ur a farking tool :action-smiley-069:
i think thats quote material :thumbsup:
do you think you could honestly run 15degree of negative camber per side and 1. not notice how f**ked up it looks, 2. how much clearance there was between any suspension components, if any.
My final question is, what did you use to measure your camber? Were you using some sort of anglemaster or a proper longacre camber gauge?
gosh got t be careful what u say around u shaney pooh
but yes i was serious about it having 15 degrees.. thats how i got it.. makes me wonder what the old owner got up to lol..
marki has no idea doo dahhh doo dahhh :)
i reckon we should both go and buy a 180 just so we can have the adjustment in camber mark does :sorcerer:
id have an educated guess and say he used a peice of timber and a tape measure to get the camber ;)
So my hair is almost long enough to cut *yay me* I'm looking at a stylists web site and what do I see?
"The salon is a man thing, with its rich leather chairs in a club-like lounge, a range of men's magazines, fashion, health and wealth literature and 'coffee bar.
You can also enjoy a complimentary glass of wine or beer with us."
:laughing-smiley-014:
First ling I swear is just a modified version of a line from the anchor man. Oh too funny.
rofl! It does sound a bit like Anchor Man....what salon is this?
Lad's pad nuts.gif apparently it's new "place" to go for hair if your not a bogan, plus I heard they have a good colourest riaa.gif
One of Jono's gay.. clients put him onto them... Or something. I wont say anymore as the bogans will flame up ;)
look out josh, ur gay side is becoming evident again :thumbsup:
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
