damn, just had to re tie the boat up, this wind is making it swing hard core was bending down tie in back up, and getting soaked by the waves crashing into the pontoon :)
Dan how much for a .82 housing and how much could i get if i sold my 1.15 housing.
I'm pretty sure they will exchange the housings plus cash their way. Might cost you $150
I can check for you tomorrow if you like. How many K's on the 1.15 housing?
And is it a 1.15 or a 1.06?
Sounds good mate :) , if thats the case order one in for me thanks.
On my receipts it says 1.15A/R. I think its done about 20 to 25000 km.
Finished modifying the std rb25 fuel rail. Converted it to twin feed. See, thats how you save money on buying a billet ally rail and then have to change to top feed injectors. Keep the same injectors and get a flash big hp supporting rail without having to buy it! Probably cost $30 bux in fittings as they were s/s speedflow. 30mins in labour time, drill and weld on fittings.
The photos were before i cut the std feed off and welded it over. But it shows the three -6 fittings i tigged on. Rail feeds have gone from 6mm to 8mm now. Should increase flow abit.
yeh your right..it does fully look home job like...but we didnt want to change injectors...new rail say 200bux a set of top feeds around same cc probably another 600-800bux
Or $30bux for the fittings. I cant charge the race car a labour fee either...so yeh. I think my old man wants it to look full backyard style...give off the homeless look. so when we win it doesnt look like were pro in anyway lol.
the extremely loud gearbox whine and the mega brakes sorta give away that look :)
ok i take my comments back now :) ur allright mate.. i personally would have taken the easy route and gotten a billet.
Mickey T's arrived and clear the guards. WHOOOOT! :)
what size rims and offset.. ur not using GTST are u?
i can assure you if we hadnt already gotten a set of 850cc sards then we would have gotten a billet top feed rail and some descent top feed injectors.
What rules stipulate that you cant be a backyarder if you have a dogbox and alcons?
Oh, heard that autronic have now come out plug n play for rb25 and rb26 with some sweet built in thingys. Like you dont need the cdi apparently as its got something similiar built in....dont know if you still need the trigger disk or not though. I could be wrong, but these are things ive just heard.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
