Probably not Col. Am sticking to the SAU members crowd and you aren't their favourite person at the moment....... Ease up on the Supreme Mod Ruler a bit and you might win some friends back.
Arhhh your going with one side of a story, shame I thought youd own me more credit than that...
Arhhh well the enforcer of the rules is always once bitten twice shy... Nothing I can do about that...
If someone complains about anything the last thing I do is protect friends, if their in the wrong ill deal with them just like I would deal with anyone else. Its only fair, and im sure you would expect no less from me not as a person but as a mod of this forum. Yes this will make me unpopular but only until those who dislike it understand the situation for all it has to offer. Afternoon.
I'm all for it Eug.
You used to be able to ask anything, say almost anything and act the fool in this forum.
I loved it!! We need a liberal dose of lighten the f@ck up!!!!
maybe chaos, charly and owned were our glue?
Oh yes, I agree...
But the pines and hope island have to be the best within an hour from Brisbane... Yeah
Hey Josh whats going on mate, your number 2 for the day... Whore up little buddy...
Top3;
abu 51
Nismo_Boy 36
Col-GTSX 35
I whore anything with legs!
I'm all for it Eug.
Its all just politics Dave, different people take what is said differentlly. I guess you just need to put yourself in their shoes from time to time to help understand a situation.
The forum is not a good communicator full stop, what is said can be taken a million ways its all down to those who read a post. It might seem harmless to one person yet really offensive to another, so is the moderators job to try and find middle ground and explain the situation to both parties.
Unfortunatlly this process will always end with one person thanking you and the other not so thank ful. Its a bit of a win/lose situation but there is little you can do to improve the situation other than to be a fence sitter, in which case no one wins and everyone ends up unhappy. Like I said its a bit like federal politics, one persons idea of a good future is anothers nightmare and its the politicians job to get lap dances, i mean find middle ground where the majority are happy.
I guess sometimes you have to make line calls where its 51/49 another but the guidelines are very sound and help define the line for us who question what to do.
Hope this helps?
i wasn't aware a situation could be 'loose' i believe the word your looking for was 'lose'
and the other 'ase' im sure is 'case' just a little short of the 'c'
'full'
this is whoretown, so dont retract my correction for no reason.
Edited by r33_racer
Spelling is not my strong point, but what makes it worse is using 3 different keyboards...
1. Home
2. Work
3. Laptop
All keyboards are different and the paterns are a little different on each and the pressure needed is also different.
In short Iblame the keyboards for many of my mistakes :D
1. Home
2. Work
3. Laptop
were u bashed as a child? or are u naturally retarded?
:blush:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
