i see your point, but when ever i have been looking at parts they always seem more expensive...and how much boost can you run on stock sr engine...i have heard of people running more the 1 bar on stock rb's. not saying that there is much different, and like always i am not sayin one is better then the other.
an sr is a new engine, better technology, but like an rb they have there down falls.
who you callin sexy.....whore man
Been looking at lots of parts lately and the SR ones are usually cheaper
Marki I ran 18psi for a year on my stock RB25 and the headgasket did not blow, 17 to 18psi is considered the limit
I ran 23psi on an unopened RB25. Buggered if I know how but it refused to die, I had another bottom end ready to go but I ended up not needing it. Certainly not something I'd recommend trying though :P I just did it because I considered the stock bottom end to be expendable lol
im actually soo use to him not picking up, i just leave messages, i get a supprise when he actually does pick up :P
really, ive never had dan miss a call from me.
i must be the favourite
Bishes *tips hat*
YEO!!!!
lol and pg2me
smich as
times change i guess...this was a few years ago when i was.
hey Bunta i need advice on a 25 build.!!!
yeah but they dont recommend it..
ohh ive been waiting for this ready.. 18-24psi on the SR safely.. :P with standard head gasket... *runs from dan to avoid abusive language from listening to sheep on ns.com*
Bishes *tips hat*
hiya marc..
it didnt ring out..
im just saying in general.. the prices are cheaper for the unliked 4 bangers.. as in coilpanks cheaper GKtech have full turbo back exhaust for 400 new.. turbos are cheaper most of the time for say T2 flanges. pfcs are cheaper.. only cause they are more common on the SR u can pick up a redtop SR pfc for 4-600 and here a R33 gtst one goes for 1250 in a matter of hours.
also clutches and boxes cheaper.. diffs cheaper. yes they are weaker but less weight play a part in the design..
b b b but they still sounds shit.....
:P:):rofl:
mine sounds like VTEC up high.. ahaha stupid exhaust..
hahahahahaha
I cant believe what i just read, there is something seriously wrong with you mark please consult a physician urgently
Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome Chrome
bahahaha
thats the funniest thing uve said all week noel...
ok i admit black adn chrom look good but still prefer black face chrome lip.. not full face chrome.. and admit a hid kit would look horn..
hmm.. i might buy a cheapo shit box skyrine 32 and put a F20C into it... :P
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
