...ill pretend i didnt see that rohan.. bahaha
determined what ur engine knock was yet.?
well mechanics seem to think its a loose gudgeon pin, i will find out if i open it for parts, though someone might just buy it.
I spank really well. So well, the spunk comes out :D
Yeh 02 crew is getting old :P
sweet as.
yeah that is old.....
hey rohan u want to swap ur RB20 for my ex.. shes up on the market again.. kms would be the same but... near her 2nd major service... her fluids need a change
i saw in ur thread lol
PM pics...and ask her if she wants to trade.
oi rohan it was the connecting pin that i said.. yeah similar thing to what the ca's do.. both of my mates did thers.. took one sil out for a flog and now a RB20 resides in it..
yeah gudgeon pin...get your names right, dont know what a f**ken connecting pin is bish.
but yeah some other guy has got the same rattle, was talkin to him last night...f**ken things...oh well rb25...and partly restore r32...dam!!
Just think of piston slap as variable compression...
I may or may not have sold my Skyline and bought a Cressida and a house... :D
Since I "joined" I've had my original 32 along side my Alfa, then 2 180SX's, the Ceffy, the GTR, the Supra, and now the M3. Managed an engagement and a house in there too.
Cressy's rock, I want one with a 1jz. I heard about your house, congrats! Did you buy off the plan and build? You'll do well in that estate
1) R32 Gtst
2) S13 K’s
3) S13 K’s
4) R32 Gtst
5) S13/rb25
6) R32 Gts 4door
7) R32 Gtst
8) E36 BMW
9) Lexus
10) Pajero
35 points, 3 license suspensions, 1 good behaviour bond. I've got no better since 02, just more poor haha
1) R32 Gtst
2) S13 K’s
3) S13 K’s
4) R32 Gtst
5) S13/rb25
6) R32 Gts 4door
7) R32 Gtst
8) E36 BMW
9) Lexus
10) Pajero
With the flash-for cash the other night I reckon I've cracked 30 now too :D
bahaha and what about the resulting piston poking out the side?
Bahaha
It's giving one side of the bore a rest
bahah :D
i have owned since i joined...
a
r32 gtst.....i still have it.
Yeah financially it's about as close to a sure thing as we're likely to find. The place is ~5 years old but I suspect the previous owners were a bit OCD lol
Hope they get my good side...
That depends, were you mooning them?
Marc your lucky you sold when you did... Back when you could get a dollar fo a skyline... :D
No point in even trying these days, saw a GTR this afternoon at strathpine for 15k and it looked pretty clean too...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
