"boots on a snake"
New, have not heard that before...
Me metrosexual, I wish... ;)
Wearing thongs and a singlet while drinking beer and cooking on the bbq and watching V8's a the same time, well if thats metrosexual than im guilty... :(
"boots on a snake"
Me metrosexual, I wish... :(
Wearing thongs and a singlet while drinking beer and cooking on the bbq and watching V8's a the same time, well if thats metrosexual than im guilty... :D
haha my tech teacher at high school used that alot :)
u do realise metrosexual is another way of saying someone's a closet fag?
cry, im crying....
Arhhhhh..... crying
I grew up watching super tourers and the begining of V8 supercars... Its not the sport i like so much it the family aspect, they all come over for a bbq and making a good old day out of it. Its like Baker tradition, the family coming round and we crack a few cold beers on a warm day and enjoy a salad and snag on a roll straight off the BBQ. Its all about family for me, the motorsport just puts a date on the weekend, and gives us something to watch...
Bit the same with state of Origin and grand final time... Its a family thing, fond memories as a kid... :thumbsup:
(Here comes my soft side)
I guess you never know how much time you will get with your friends and family. They could be gone tomorrow, so time spent together is good time always... :D
So its special time, going to the drags, fishing, watching bathurst, watching an NRL game at suncorp, gathering for birthdays, christmas and easter as we grow older (im the youngest of 3) we all have started our own families and we have little time for each other these days and its a great excuss to get together again and have a big chin dig...
However this year is different, ill be there with my dad and older brother...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
