I want a supercharged M3.
This man know's what its all about.
word on the street was u had aids...words on the street now is u certainly do have aids
Driven many M3's? Raced many M3's? No. Sit down.
Is there a name for what's wrong with you?
Red nut with a computer?
oi fochers. whats the power delivery on the supras like? a tt rz im talkin (94 model, so no vvti)
270rwkw, 264 9.0 cams, std turbo's. 2nd gear useless?
savage.
interesting.
are the stockers reliable? i.e what are the chances of turbo wheel departing and entering cat/motor
comparable to the skylines?
sequential system is quite lowly and has a fair bit of restriction on them most owners replace the sequential system..
CT turbos are fairly good. US version JZA got steelies.
yeah the whole driving of your car can lead to problems like that
much safer in the backyard :(
bahaha OWNAGE...
i chuckled..
watching oceans 13.. its not as good as i thought... just started but..
i rather a JZX100 chaser... 1JZ and only 5 spd no getrag is that correct josh? lil lighter and 4 doors.
Yes, all manuals are 5 speeds. JXZ90 is lighter then JZZ30 Soarer. I'm not sure what the JZX100 is like, but I'd be safe to say they should be lighter, if not the same.
This is a good forum. http://www.jzx100.com/forum/
interesting find josh is it aussie site.?
if i didnt buy another 180sx last week i would prob get a JZX100 next year.
Hi Melvin.
Depends how the go peddle is used and what tires are on it.
The one I drove just had an exhaust and FMIC, was lots of fun for a stock car. Smooth power, punchy down low.
Shits on skylines.
nothing is reliable. Chance's are the same as any other factory made ceramic turbo.
You can tickle 1.1 - 1.2bar out of them from time to time if your nice, but thats not an everyday thing.
i'd go col stylez. i.e china copies & ebay specials :sorcerer:
none. i've seen youtube videos. thats enough eveidence for me to back up my claims re eurotrash
thats Mr Ginger to you
There is more to car package, yes total package then outright power.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
