i think mark was talking about the 'copy' drifteks. not the ones you have
nah no copy drifteks
but the old 4 stud ones and 5 stud clear easially. but the new 9 hole ones im unsure of. they just clear R33 GTST calipers
no i dont think there are copies of driftteks.
bee*r rims are different and look hotter but for the price i would buy the 18" teks when they arrive...soon very soon.
yeah i might wait for 18"
It cuts an ok ring :)
new 275's kinda make me cry though. Did a gear box mount from flat changing :D
bahaha... flat changing. doesnt the porshe have a poor engagement system or something u wer telling me.
i cant wait to leave 4 big black skid marks outside ur house and down ur street :(
i wanna watch :no:
same mate same!
with joshwa's help it could be even earleir than anyone thinks! :no::D
ohh. joshwa fetching parts..
i worked 11hours today and spent 15hours at friggen work. casual rates FTW
They do, if you keep that in mind and dont try and force it in it's no different. Just what your used to, drive it like a GTR box and it'll be biting back, spend some time getting used to teh goofy build and it's perfect
Nice, cant wait to see it finished... I remember the day you got it...
I remember talking you or helped in talking you into swapping it for the S2... :D
haha i remember that too!
im hating u for it now though. i coulda had a 700bhp 33 gtst by now :(
i wanna watch :)
nah im good at sourcing parts, he's helping me write a little letter
morning all forum died again earlier?
morning :w00t:
yeh it did, what else is new though lol
yeh man looks schmick
im pretty sure andy's got a similar setup.
it'll be capped around 300kw though with the std manifold
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
