Can I ask, and answer honestlly...
Would you modify a brand new car???
Considering you have a perfectlly good car and all its gonna do is burn more fuel if you f**k with it...?
Also you would loose factory warranty and it could end up being a 50k+ mistake???
Would you honestlly modify???
Cause i think im talking myself out of it, that and id be killed by the mrs for touching another car...
Pussy!
also like to say thankyou to optus for putting ther technical service team in friggen india. or should i say hire a bunch of the over ther to take my call. i got up the lady telling me it was my modema nd router problem wher it says my optus account has been suspended. spoke to the manager after 20mins of asking for him and shouting at her. and in the end i entered my credit card details in again and redid the account. i just needed my damn password which was suprisingly the friggen alphabet!
thanks optus. U FAIL
who should i change my internet account over to. i want 20GB p/month at least and no slow shit connection for cheap as possible
and cheers shane for sending me the sms sayin bank is cancelled. stupid rain. looked out the window at 3.30 and it was pouring. my mate checked the site told me cancelled then shane sms. cheers bud.
when u guys headin out next time.?
3000th page!!
uh col since when do cars use more fuel when u put a free flowing exhaust on?
and hell i would modify the new GTR
40 PPP n00b :ph34r:
no worries mate :nyaanyaa:
it was wednesday, but not sure now
3000 pages of utter shite all in the one place. Congratulations to all those involved!! :)
40 PPP n00b :)
Oh the irony..........
el oh el
computer is giving me the shits: Anyone know why all of a sudden when i save a file it defaults back to the "documents" folder rather than the folder you have been working in?
why its sucks is i make a document then export a pdf for client approval and every time i make a pdf it defaults back to documents folder so you need to navigate back through the folders to the client folder your working on?
make sense?
its shit and takes up my valuable time.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
