i see, i didnt think the Nagisa Auto ones would fit, at any rate, $1000 for tail lights is a bit of a kick in the nuts...is $1000 to my door your price? explain yourself :) !!!
Not exactly. Forum rules prohibit me from trading on SAU as I am not a forum trader.
However, if you were to give me a donation of an amount approx $1000, then I would feel that it would be necessary to give you a gift of some kind. Seeing as it's Christmas and I know that you like the Nismo GT LED's then I think that would be a superb present for you.
Even if people buy in groups I can still 'accept lower donations'.
Probably the best way to explain myself is.....I have the ability to buy things cheap...It costs me nothing to make the order or have it delivered.....If I can save you a few dollars then it makes me happy to do so. I have no overheads so it's better for SAUers as they can save money on their parts. I get into trouble for doing it as I'm sure I will for this also. But it makes it worth while if I know I have provided a service to the Skyline community.
u are gold man, lol, if i run into some money that i think would make a worthy donation, ill be sure to look up your fund,
cheers for the info
"you cant catch me because I'm the gingerbread man"
the sherk gingerman is better looking, and "catch me if you can" is way cool.
f**k the police!
BHG = Blown Head Gasket
Symptoms:
Hard to start
Rough as guts Idle
Temp spiking up and down
Currently to chicken to check the oil for mayonnaise...
dont let it overheat. if u do bye bye head
injectors is a khent
for the retarted maybe
peace yo
GTFO
^^^THIS MAN IS CORRUPT^^^
I dont have any info the cops said in there words "Nothing is going on, nothing happening, go back inside"
They all gone now, not sure what was going on... They didnt end up taking anyone with them so im not sure what the go was...
Not my direct neighbour, it was in the street behind my place which I need to drive down to get out of the estate...
All happened this moning... Dont how what it was about, just got told to go home and sit tight...
Was on my way to work and told I cannot drive down the street, I was turned around and told to go home....
So i ended up watching Kill Bill Vol 1 & 2 :D
noice, talk about an excuse for a day off...
kill bill is an odd movie, havent seen the second
Hello all,
Long time no chat.
hey there gary :D
Edited by RusH_
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
