got torque????....
and no revs!!! ;)
jk..farken monster!!!!
lol
myeah mine wont be doin over 7k so i guess thats about the same really.
oo that should flow really well but still have some nice response. it will be interesting to drive against you on track of course.
softcock, rev it til it stops making power...
im probably set my limiter to 7200 as thats what robbie (RIPS) recommends the motor is built for
would be good to have a built 25 reving to something spastic like noels but Im sure my wallet has so far been considerably less damaged than noels!
how many rb30's have died from over revving? i havnt seen any
minell be making power upto around 9000-9500, im confident itll be happy at them sort of revs
You're going to need to make some oil gallery modifications if you want to run it at 9-9.5k and think about buying a forged crank.
The RB30 isn't designed to rev that high reliably especially when you are going to be making 700awhp.
Speaking of which, I need to talk to you about those modifications you will need to make....and it's not doing any dumb shite like knife edging the crank.
we need to talk...
Hey Col what is the go with the user sigs?
Mine is cut off at the last part of the pic, it is one whole pic and I have noticed quite a few others with halve a line of text at the bottom.
yo shane you back on the 3L thing - just trying to make sense of all that went on in my absence lastnight?
ive never been off the 3l thing lol
speaking of such, 3hrs of machining to go on my girdle, i hate weekends and public hollidays :D
try installing ie6 - it dont like ie7 and the smart cookies of sau reduced the sizes of the sigs - genious' :D
:rolleyes:
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
