Hi Tim ;)
So, um, do you like stuff?
Yep, stuff 'n' shit. Lots of it too. Sick.
nigaz
so how many are signed up for the scc cruise?
~100+ cars at this stage.......but I guess a few of them will hide if the weather turns bad......
  • 3 weeks later...
<!--quoteo(post=5577986:date=3 Dec 2010, 02:34 PM:name=Slow S13)--><div class='quotetop'>QUOTE (Slow S13 @ 3 Dec 2010, 02:34 PM) <a href="index.php?act=findpost&pid=5577986"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->yesterday was the 2nd fool <img src="http://www.skylinesaustralia.com/forums/public/style_emoticons/<#EMO_DIR#>/wink.gif" style="vertical-align:middle" emoid=":nyaanyaa:" border="0" alt="wink.gif" /><!--QuoteEnd--></div><!--QuoteEEnd-->
ooh scathing remarks from the guy who didn't read his comment properly <img src="http://www.skylinesaustralia.com/forums/style_emoticons/<#EMO_DIR#>/tongue.gif" style="vertical-align:middle" emoid=":D" border="0" alt="tongue.gif" />
stepped in a doo doo there!
LOL...shutup fool :thanks:
WTF is up with showing HTML markup code in my reply?
Win7x64 post fail.
Check the feedback section, others might have noticed something similar. Or maybe they haven't, and I'm not up to that section yet and cbf skipping ahead to check :P
Oh and morning whores!
LOL yep did see a few things already noted there - cheers!
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
