Yer should be able to make it to the cruise looking forward to it.. are us northerners doing a premeet?
We have to be there at something stupid like 9am. If you want to meet me somewhere earlier than that bring coffee or GTFO :P
In other words, we can have all the SAU boys meet somewhere and then cruise?
Good people the night is young and the scotch is flowing.... I have tommorow off, hell to the hiz ow
Dude it's like you want me to dislike you, ls1 in a skyline and a day off on a Friday,. FRIENDSHIP OVER!
Moaning all
Morning Cap.
Another wet one! Was going to paint but guess gonna have to do something else.
Rain rain go away come back another day (in a Month's time)
Edited by Ants
Morning Cap.
Mornin', but yer it's wrecked my plans for willowbank drag skids this weekend :( .... The Abomination will have to wait another week before its virgin pass.
AFTER THOUGHT: and next weekend I'm "pit crewing" for my mates burnout car at the Gatton sprints (if the ever unorganised twit can get his cam in and tuned in time :/), so it won't be next weekend either :rant:
Lol. When you want things done there are always stumbling blocks.
Predominantly, these hick ups are caused by people we rely on to get things done. In other words life would be bliss if people actually gave two sh!ts!
Yep like if I knew my Nissan speedo couldn't recognise the Holden input signal would of been nice to know... Or
(Warning rant incoming)
if the parts for my extractors didn't take 3 weeks, or my leads weren't farked, or knew I couldn't use the fly by wire throttle body, or the tail shaft didn't take 3 weeks, or that no one has done a wiring loom diagram up for a 33/LS1, or if they ordered me the right ratchet shifter, or my original loom wasnt completely wrecked, or i knew i had to plate under the shifter and have heater hoses hooked up for the mod plate and In general if everyone that I rely on wasnt a slow lazy fark that'd be great!!! :rant:....
You should of just dropped in a rb25/30 and none of these things would of been a problem, well all except your butt plug your using as a shifter :P haha
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
