Rip on Nick and his abomination, all the whores do.
He probley has no idea what that is, but If I remember correctly pawnd used to own a very sexual r32 on professors/Meisters If I remember correctly that is lol
Yeh, back in the day. Now I am on two wheels.
Guessing from your avatar, the abomination is ls1 33?
Haha got it in one.... Yes it has been dubbed this, I secretly know they're all just jelly and wish they owned it on theyre p plates :P
So borrrrreeeedd! Waiting for the last few drops of oil to drain so I can do the sump plug back up.... I'm thinking about not bothering to put the front diffuser back on - too annoying when I wanna work on it...
U could of made me a samich I'm bloody starving, rosters are killing the dragons :/
Where does this said bowling happen? If it's some where out past buttf**knowhere, you better make it an overnight cruise.
Well, I'm sure there is a bowling alley somewhere between tbar and brissy there's a good alley in tbar but that dosent suit the brissy guys (I'm fine with anywhere in brissy apart from indro/st lucia/toowoong)
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
