Because SAU people can't be considered mates :dry:
Kinda disappoint...
They are. Don't get me wrong
I can kinda understand as far as which direction the club is going, but in my mind asking as its forward that's all the matters
Is it though? That's where the question lies.
Ok I must of got you wrong, cause I sure as hell class alot of the people I've met through SAU as at a minimum of aquaintances and the select few that talk to me on the reg I'd class as mates, he'll most of the TSO boys I consider great mates of mine :wub:
*weather that feeling is mutual I have no idea lol
Oh hell yeah! Made some great mates through the club as well! But over the past few months, I haven't had a chance to scratch myself, let alone meet with other mates. My best friend is getting married in September and I'm meant to be her maid of honour. Been that wrapped in club stuff that I haven't been able to help her with that. On top of the fact that I've been putting hours in to the club which has been detrimental to my productivity at work and has cost me financially and emotionally.
am...
I your mate???
MATE!!!!
I can understand this Tony, especially with long work hours and kids to look after. Hell, I don't even have kids (unless you count dogs).
This is the sole reason for me not wanting to contribute more to the club, I barely have the time to sort my own life out most days anyways.
Having said that I do want to get to more club dinners, meetings etc, Just haven't had time.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
