Because SAU people can't be considered mates :dry:
Kinda disappoint...
They are. Don't get me wrong
I can kinda understand as far as which direction the club is going, but in my mind asking as its forward that's all the matters
Is it though? That's where the question lies.
Ok I must of got you wrong, cause I sure as hell class alot of the people I've met through SAU as at a minimum of aquaintances and the select few that talk to me on the reg I'd class as mates, he'll most of the TSO boys I consider great mates of mine :wub:
*weather that feeling is mutual I have no idea lol
Oh hell yeah! Made some great mates through the club as well! But over the past few months, I haven't had a chance to scratch myself, let alone meet with other mates. My best friend is getting married in September and I'm meant to be her maid of honour. Been that wrapped in club stuff that I haven't been able to help her with that. On top of the fact that I've been putting hours in to the club which has been detrimental to my productivity at work and has cost me financially and emotionally.
am...
I your mate???
MATE!!!!
I can understand this Tony, especially with long work hours and kids to look after. Hell, I don't even have kids (unless you count dogs).
This is the sole reason for me not wanting to contribute more to the club, I barely have the time to sort my own life out most days anyways.
Having said that I do want to get to more club dinners, meetings etc, Just haven't had time.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
