Got hit 517 bucks to rego the abomination for six months :(
The last six months rego I put on it I hardly drove it
That's such a rip...but I guess u do have an extra 2 cylinders so you have the pay the price for that extra pollution...
TBF the GTR rego is not that much cheaper being $425 for six months and is due next month for me already and I haven't driven it for over 3 years now.
so, when are WE going to race?
Luke, Luke, Luke what are we all gonna do without ya?
going to need more than that crotch rocket
not sure about you guys, but I just hate waiting for my car to be completed, and if I had the chance I would do the work myself.....except I'm not a mechanic and would no doubt f@#k everything up.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
