I wanna come along too. Will be good 4 me to get some fresh air.....hold up!!!! I mean the smell of hi octane and burnt rubber oooooo yeah!!!
... And after the event some are staying around for the test and tune right, righhhhhht?
I see what you did there :P
She went to sleep
So when do I get to see this abomination? I'm pretty keen
Had a look at his build thread yet Zac? That will give ya pretty good idea to start off wid mate.
Essentially, I second 90% of Mikes crap, disagree with 90% of Nicks crap, reckon Ants is on the ball 90% of the time and believe that Cowdy could be 90% better at whoring.
Did we just have Mrs Cowdy ask how to whore? lol!
Welcome to the club! Who's coming to the montht meet next week?
She went to sleep
Haha I'm hopeing to have it out at this drag day, sporting some new goodies... Don't get to exited, ATM it's just a stock LS1 from a VZ SS (well, it has extractors exhaust intake and a rough tune... But u get the idea) once I can get the new lumpy stick and a decent run on a set of rollers we'll see how it really goes.
To fulfill your desire temporarily: Drjfi9U.jpg
I disagree with 75% of everyone... Also ill be at the meeting if brian is still giving me a lift
All this doe's is fuel my hatred...
LOL - but totally true!
Did we just have Mrs Cowdy ask how to whore? lol!Welcome to the club!
Details Tony, I WANT DETAILS :)
I have seen in and watched the video it looks pretty nice. But nothing will compare to seeing it in person.
On another note I am really sick of this hoon label. Driving home a swift was going 70 in a 60 zone. Red p plater. Then there is me 60 in the 60 and I get pulled over and I asked why me not the swift it was speeding she said your in a hoons cars. I'm like "that's offensive. It's an import and I do not hoon I just like this certain car. I could do more damage and get away with it in the Swift than this. I would do one chirpie in this and get it impounded."
She replied with "ill be back." Went back to the car came back and was like have a good night and got back in her car
Hey I'm only new to it... Give me time and ill be called an escort
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
