Sup Nick, did ya get dat oven fixed and get dat cocain....rrrmmm... Coke reorder done
I've seen Tony in real life mate and da Batman suit would = Epic super hero failure
I am the Dark Knight
come on down, ill hook you up ;)
Yeah bro. Hook ups all round.
meh, knowing tony(which I dont), hed crack the shits and leave us because he wants non skyline friends.
But non-skylines make competition more fun
Good morning people!
I feel like I should pay for the drag today.... Its been awhile........
Doooo eeeet
Hahaha. My turn will come soon and I'm not looking forward to that!
I had drifted back into sleep....only to be woken by a 'Mummy, I've peed the bed' 'Why didn't you get up' 'Because I couldn't because it's too cold and I dont know where the toilet is and I might have peed in the cupboard' translation= CBF
Hahaha... this arvo I will go grab some redbull.
Mr ants, Luke, Brandon *raises can of mother cause they had no redbull*
Hella-yes!
I've gota source to get all the freshest flat brim styles so his never behind the times when rolling in the flushas Pinny ;)
#@Hank Scorpio
That grave your digging..... It's not getting any smaller....
So who is coming to the meeting tonight?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
