Watching ice age with Tyler whilst enjoying a Kirin. :)
I love Ice-age hav da whole collection here! Btw had nine beers ova it, got on to Whisky now death comin!
drove through springbrook and mt tamborine etc this morning, good fun without too much rain :)
Must of passed at some point. Beautiful drive indeed! Edited by Ants
Mike, so being a knob runs in your family? :P
Welcome Dave. You can join us in giving mike sh1t about his boat.
Twas a mere tinny when I found it, shoved down besides someone's house. $1700 is a good price for a tinny right?
C'mon matey, Mazda 3's pull hard. Your petty single turbo 6 has nothing on the MPS!
mazda 3s are good.
missus has one.
mps's are awesome.
old shape I reckon goes better than the current model.
would own, if I could stop spending kesh on the money pit.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
