morning all.
nik, you dont have input on if you have a lock up converter?
Nah it's not a lock up one because I went a full manual valve body with a vacuum feed (no PCM for the gearbox)...
It's an odd feeling on the highway, also sounds weird through town when the engine note dosent change as you change gears lol
Captain Feathersword, if you are chasing someone to shim your diff I would chat to Option 1 first, they have been doing that for many a year!
Ok, I'll drop Dan a line if I can't find anything locally. Because that's a 3 hour drive + tolls + about $100 fuel.
should have gone rb, wouldnt lose.
This. Or VQ
Hahaha. Should check the current temperature on the smart phone. Freaking 8 degrees and feels like 4degrees says the smart phone.
Car said it was 11deg when I was on the way to work
That's because holden.
Moarning slarts. SAUQLD site is now read only and all the action is here - for non-members.
Members get access to the cool section.
so, you went full retard.....
