Better pushrods is an oxymoron.
For tyres I would see what sort of money you can get Federal EVOs for. Or just use the 595s and get them hot, Noel used them back in the day and they performed well after a large burnout! Also Theo Woolett ran a 9 on them in his GTR so they cant be all bad!
But in all seriousness 90/10 shocks is what you really need. When I first upgraded the turbo in my old 32 I had no traction at all, if I went to pass someone on the highway it would put on a smoke show! But i set up my subframe bushed for squat and got the shockies set up to keep the weight down over the rear and the problem was solved.
In fact I wager that even with bigger, better street tyres you wont get much of a result until the suspension is addressed
nik, some sound advice here.
you will probably find you get more traction if you swap out your coil overs and put your standard struts in.
I don't have standard struts :(, car came with coilovers.
*first world problems jpeg
ur skatin everywhere :woot:
Yer it's slippery as hitters hair style, but that gives you an idea of what I'm dealing with (which I'm sure any guys with big power can relate to [even if mine dosent have big power the stall makes it feel like it dows])
ROFLcoptor
:/ Seriously bro. Buy a Maxima.
LOL (and it continues)
Yer I'm regretting not going the 90/10s like I wanted to. Then everyone was like "no no get coilovers and just soften them up youll hate 90/10s" :dry:
coilovers are too hard for ya - as Luke mentioned struts TWTGO
Edited by Ants
Lawl. Take your car against the abomination at drags :P I know that you said you couldn't be there, but I can drive her :P
I could do that... or I could take my car with me and try it out on the lovely new range they just finished on my way to where I am going... I am yet to see the abomination and I am looking forward to it.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
