We now have online application forms for membership!
Anyone who is looking at becoming a member can do so and check it out. :)
Let us know of any bugs that you encounter.
you should post a link bro.
https://docs.google.com/forms/d/1NndJmTf9t9dgkT_PCSWa5WeP7Iqkp7dOFMn2Ra-_kQo/viewform
better ;)
Edited by Ants
You can come. If you bring pie
I was bullied heaps in school. In Primary School for being smarter than the rest of the kids and using 'big words'. In High School I was the white girl listening to rap. I also never really wore the girls uniform. Victoria gets cold in winter so I wore pants and black skate shoes unlike the girls who wore the winter skirt up around their huha somewhere. I'd rather be warm. And did not have the desire to have sexual encounters with the entire male population... And then some shit happened in my personal life, I got really depressed, started hanging out with the cutters and listening to metal, so from then on I was an emo kid with a bad attitude.
I like alcohol
I like this idea
I went to UQ briefly.
Just cos I'm female, I drink wine and I went to UQ I'm pretentious. Far Q
God we have a lot in common!
I like alcohol
I like this idea
Wife swap?
Regatta Hotel. Worst service of any hospitality venue I have ever been in. Bad doesn't even begin to describe it. Tonight I was unseated from my table because they f**ked up with a booking and then tried to take my meal away before I was done eating.
The only reason I set foot in the place is that I can spit on it from my balcony.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
