Brunet with a pink streak :P
Still Connie's bitch?
So connie... You in?
In with what?
Drinking yes.
Movie making in the wave pool... Probably not... I would need copious amounts of alcohol and all of Tony's drugs to even consider.
I have my bitch, he keeps me satisfied.
In with what?
Drinking yes.
at least that was not a definite no. Lol
In with what?
Drinking yes.
Sounds like a plan :P
OHHHHHHH SHIIIITTTTTEEEEEE
well it's been really busy 2nite here. In fact there has been soooooo much sh!t discussed that I don't think I need to take a dump 2morw.
I'm gonna call it a nite ladies and some gents
p.s. I want a nite out that doesn't involve in Tony gettin doubled team in the suburbs of Springy hill and Fortitude Valley!
Gnite and Lights out!
Night Ants.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
