Thanks bunta. That has explained a lot of things :thumbsup: Where can we get a crank trigger from?
Ross make a kit, MSD do, you can get slots machined into your harminic balancer, lots of options! You need a ECU that can accept a crank trigger sensor input, but thats pretty much anything other than a power FC lol
Just got a invite to a meeting, The Director General of the Department, the Executive Directors of the 4 regions in the state....and me, and I have to demonstrate to them why the Ipads are good. Bit of Friday fun :S
Great. More money to burn..........
So the Ross kit. Need to source an ECU next as now I'm really confused as to what I should go for :/
Just make sure there is no pron on the iPad you use as a demonstration :P
What ever you can get for the best price I reckon, Wolf, Haltech (aside from my personal vendetta) Adaptronic, Vipec, Motec ect are all top line ECUs and will do the job.
Infact Haltech CLAIM that their ECU handles the timing Jitter issue better than the others, and there appears to be some evidence supporting it. Perhaps you could give Haltech a go (cant beleive I said that) on the normal CAS and if you experience an issue go to the crank trigger?
I was thinking of getting a Haltech so that may be one way to do it. I will have a look at their website again and also talk to Hi Torque Performance.
:thanks: 4 d advice mate.
No worries! Mercury are selling Haltechs really cheap at the moment $2000 installed and tuned. I would get it from them, get them to install it, put a base map in it then take it where you please to get tuned.
Edited by Bunta
Looks like I may be able to procure a brand new Hatech Platinum Pro for less than $1,400.
Anyone want a brand New Apexi PUSSY FC with HC :D ?
Oh this is going to be good...Pie charts and bar graphs time, Throw in some user testimonials and crap about % of user uptake.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
