I've really better than Emma W. you guys need to open your eyes to the talent out there!
Pron and more Pron.
Speaking of pron. got quote back for fixing damaged external HDD........$2k and not guaranteed to successfully retrieve info in full!
So yep 'bye bye' ext. HDD :(
Pfft small Boobs don't sit any one. On that note I leave you boob noobs to your Emma faps. Night all
You just have no understanding of the boob/girl ratio. Some girls rock big ones well and some don't.
Pron and more Pron.
There is better than Emma but that doesn't mean she isn't a hawt bish.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
