Morning!
Spry suggested new afms? Did he follow that up with" I have a pair here"? My suggestion is lose afms all together.
yeah what the actual f**k. Antz, to be honest a few things being said are worrying me a little! Some of the stuff you are being told makes very little sense! Edited by Bunta
Morning!Spry suggested new afms? Did he follow that up with" I have a pair here"? My suggestion is lose afms all together.
I will. Matt only recommended this with Apussy PFC.
morning all. VW calipers arrived yesterday, gotta love cheap parts :)
Why VW calipers and for what car???
QUEENSLANDER!!!
+1
Not going with MAF. Gonna ditch em cause now Haltech Platinum Pro ECU (although could still use them). Andy, I will make sure that happens. What I need to do is find a tuner which is more than profound in tuning this type of ECU on the Goldie!
+1
If you are going for a new tuner have chat to Sean, he really is very good at his job and is a decent guy on top of that, always happy to explain to you what is going on in ways that you get.
Also one of the best tunes I ever got was from a young guy over at chiptorque as well.
It was a literal "we'll that escalated quickly moment"...
either way his can go and f**k a catus cause I'm not haveing anything to do with him.
It made me happy that someone had an actual that escalated quickly moment.
Yep litteral that escalated quickly....
[copy pasta from my Convo with Chris]
Was a culmination of things, he'd over stayed his welcome at my house, was being rude and generally a flamin mongrel towards me. Then I was sitting on the lounge and he tipped a glass of water on my head which f**ked me off, then like 10 minutes later spray painted my head with red paint when I was sitting down and I just lost my shit punched a hole in the wall, got into a bit of an argument and he stormed out side slamming shit around so I told him to f**k off. Then he pushed me and I pushed him back and as soon as I put my arms down he jumped on me and nearly f**king choked me out.I didnt even want to fight the dumb flamin mongrel, hence i didn't have my arms up or anything I just wanted him gone. My neck is f**king killing me
:rant:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
