I've heard if you look into the mirror and chant "Charlie, Charlie, Charlie" he will appear in Whoretown!?!?!?!?!
We can't all be LS1 haters, I will be putting an LS(insert number here) into a car in the not too distant Future but I've got a bit of a timeline and process to go through before it hits the streets....28 months and counting.
Sounds good bro :)
Aslong as its not a 33 I'm in favor of it lol
Yes factory power figures are how you decide what a good engine is.
Well how do you decide what a good engine is then because there are alot of big hp LS motors out there?
You tap away at your little keyboard drivelling on about quad cams and volumetric efficiency, but its not my problem the motor you like is smaller, hell blame Toyota but don't run around the place going on about how I have 1.7l more then a 1uz and therefore it's a worse motor.
people think the Earth spins because of gravitational forces....completely wrong......there is an LS1 in the core of the planet that is causing the spin....a few have been put in space to move the planets around the sun too
I didnt say it was worse because it was bigger, its worse because it is a truck engine with its design roots in 1955. and 1uzfe can and will match a LS1 more or less mod for mod, because of the magical concept of efficiency that you don't seem to grasp. My brothers 1uzfe made 205ish rwkw with an exhaust and flash tune.
I am not doubting that a LS1 can make power, its just they are crude as f**k and I appreciate a good ole engineering feat.
Good tanty though! Made my morning interesting.
Surely its an Ecotech.
Anyway enough superior engine torque (< :ninja:)
Pissing down rain here, makes it possible to keep the floor clean :rant:
Nice Pun, hi 5.
Though not sure how the rain helps keeping the floor clean...unless you are collecting the water and using it to mop...
Edited by RusH_
Quad cam and 6 bolt mains > pushrod heap of 'murica shit.
In other news my brother in law has decided to buy a R35 GTR. I am very excite. Have wanted to drive one for a while now.
This is true
Yer hence why my motor makes 60kw factory more than a 1uz....LS > 1uz
This is not true
LOL just a lot of us are in the 10+ years of SAU membership, I've been pretty scarce since I moved on from the LED business, that was the only thing keeping me here as I said good bye to the R34 about 3 years ago :(
Hiiiii Dannnnn!!!
1000% NOT a Skyline
De Lorean!
Don't confuse him with big words!
He is from Gatton...
No but if you have a bigger motor that can only pull the same as a smaller motor, then what's the point? It's like my fat chick remark. Remember!?
I understand VE I just don't give two shits for it when comparing smaller engines cause all I think is "why the f**k didnt they use that same technology and make a 6L?!"
But yes wet weather makes me a grumpy f**k...
so, whats the kw/l difference?
an extra 1.7l for 60kw?
Nice Pun, hi 5.
I meant impossible... What's going on Mr Steve? You missed a good day on Saturday :P
I dont hate ls1s, I just like giving nik shit about it.
he knows I have respect for it.
This is not true
Is is true! Mine made 250kw factory a 1uz makes 190kw factory, 250 - 190 = 60 :thumbsup:
And yes yes I remember, the point is mines bigger than yours.... Sounds better aswell :P
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
