I know, not a real redhead... But who really cares??????
Quality I want quality rangas Rhinorebel!
Hahah your learning... Good, goooood :)
He is, isn't he! Im really proud of our little cowdy ;)
when run in, powertuned and issues sorted.
That's cheating Luke.
Ahhh ok then. They should make glass headlights for us :P
They can make anything glass, I've had a lot of custom order stuff, things you would think impossible from glass and they've made them.....basically I send a technical drawing, or better still the actual item and it can be cloned, or made better depending on what you want.
Would be nice to order something that didn't involve visits from the State Drug Enforcement guys, they thought they were onto something hot, until they realised it WAS an actual business.
They can make anything glass, I've had a lot of custom order stuff, things you would think impossible from glass and they've made them.....basically I send a technical drawing, or better still the actual item and it can be cloned, or made better depending on what you want. Would be nice to order something that didn't involve visits from the State Drug Enforcement guys, they thought they were onto something hot, until they realised it WAS an actual business.
Not surprising that would happen to legit business owners. Sounds really fascinating what you do and what they do. You should post some pics up for everyone to get a better idea.
lol, sounds like a fun day at the office.
Seriously though, ball park figure on a R33 series 2 headlight lenses?
Apparently I was "high risk" due to having a Chemistry and Pharmacy Degree and was ordering large quantities of lab equipment.....c'mon guys would I make it *that* obvious if I was up to no good? "Hey look at me!!!"
No idea with the lens cost, I'd need some dimensions etc etc to get an accurate idea, I'd say they will want one to play with and mould also as it's too hard from a drawing to get it right.
but we do not have r31's yet have glass headlights I wonder...........I wonder.......
Well they had to do something right with the R32's, i mean shit, they bodged up the body bad enough, the least the could do is stick some glass lenses on the headlights!?
Lens request sent, I'll see if it is possible.
I'd say they'll need both a complete L + R headlight to make sure all the clips etc etc are still functional with the glass replacement, yet retain the desired strength. It'll be lab-grade Borosilicate, so nice and strong :)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
