Does anyone know where I could buy a single Ball bearing Ball of certain size?
Also, could someone please measure the ball size of a turbotech boost controller?
Also.... I have an excuse for the drags now, my boosts were being stolen!
Try GCG they have a good arsenal of single ball bearing turbo chargers and sonic performance (MTQ Performance) in Brisbane.
Not sure about measuring the ball size if a turbotech boost controller though?!
No I don't want a turbo, or a bearing. Just a single ball. Mine fell out.
edit: out of my boost controller, not my turbo. I'd be concerned if a bearing ball fell out of my turbo.
Sorry my mistake. I'm not sure on that one. Il leave up to the experts that know.
Anyways I'm going to bed I'm stuffed!!!
Nite all.
I am the very model of a modern Major-General,
I've information vegetable, animal, and mineral,
I know the kings of England, and I quote the fights historical
From Marathon to Waterloo, in order categorical;a
I'm very well acquainted, too, with matters mathematical,
I understand equations, both the simple and quadratical,
About binomial theorem I'm teeming with a lot o' news, (bothered for a rhyme)
With many cheerful facts about the square of the hypotenuse.
I'm very good at integral and differential calculus;
I know the scientific names of beings animalculous:
In short, in matters vegetable, animal, and mineral,
I am the very model of a modern Major-General.
The fu*k nick..... Where do you get this sh*t.
The depth of my soul, and I was looking up Gilbert and Sullivan plays lol
WTF Nick!!!!
It was stuck in my head ok lol
You really are a strange person Nick
Apparently
Nick put the crack pipe down.
Never!
