My wisdom teeth are pretty bad. According to the Dentist they're pressing the others forward so it causes a crazy amount of pain in my jaw. All 4 of them have be removed surgically so this is going to be awesome fun.
wife had her 4 removed last year by surgery.
she wasnt to comprehensive afterwards.
I havnt had mine touched.
coz im awesome like that.
When I had my teeth out I wasn't allowed to sneeze because the 5th and 6th teeth caused a hole into my sinuses that they had to patch up with part of my cheek!
Good times. Still didn't miss my game of rugby that weekend! Lol
aren't you a trooper of a recruiter ;)
It's ficked. There are so many shit ones out there that you really have to go above and beyond to demonstrate your capabilities. It's as though you're actually starting from negative 100 as opposed to zero. You do what you have to.
So many shit ones.
Understood. Sounds like your doing your best mate though and that is all you can do.
So many shit ones.
Lack of qualitative candidates Bunts.
By "so many shit ones" I mean recruiters. There are recruiters out three who don't understand what the role is they are trying to fill. Just how there are shitty tyre fitters who don't know the first thing about proper rubber.
Problem is, you meet so many people when the client gives you a job brief and then when the role is changed or put on hold, you're the asshole for what happened.
There's some good but a lot of it is actually quite painful. But you do what you do. There are candidates out there who would call me shit. But there are others who love me to bits.
By "so many shit ones" I mean recruiters. There are recruiters out three who don't understand what the role is they are trying to fill. Just how there are shitty tyre fitters who don't know the first thing about proper rubber. Problem is, you meet so many people when the client gives you a job brief and then when the role is changed or put on hold, you're the asshole for what happened. There's some good but a lot of it is actually quite painful. But you do what you do. There are candidates out there who would call me shit. But there are others who love me to bits.
I see. I do think the recruitment industry has been flooded by wannabes and the amount of crap (recruitment agencies) I get from social media network is insane!
TBH have had my fair share of bad experiences (some way too pushy and still push I mean WTF?!).
I'm almost inclined to not to use recruiters because of that (no disrespect mate)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
