Evening Ants and Luke,
Gee I get a better reception here from you guys than the family when I get home from work
We are your family Chris. We are.
Need to make a grander entrance when you get home...you need theme music.
Mario!
I like the empires theme music from star wars.
and, no, she doesnt....
This could also work. And it's true. I asked her.
Mmm 2006 bit before my time.... I was in grade 9 :/
I graduated in 2006.
Cricket is turning into top viewing. Poms are killing it :P
[awaits barrage of sledging from Aussies]
Poms are doing well. Compared to the Aussies at least. Feels good to support the winning team :P
World war Z, anyone seen it? Thoughts.. don't want to waste my time today
Seen it. Interesting take on the whole Zombie thing.
Might want to revisit your definition of winning as we have a (very slight) edge in the match now
Could go either way from here but aussies definitely slightly in front.
+1 to Marty
The Poms just let our number 11 score 98 runs on them taking us from looking at a 100 run deficit on the first innings to having a lead of 70 odd, then losing 2 wickets before erasing the deficit!
That gives the Aussies a definite upper hand. However Cook is still in and he is farking amazing >_<
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
