Nissan a r382 race car from the late 60s :)
Tough bit of kit: http://en.m.wikipedia.org/wiki/Nissan_R382
they turbo'd them the next year for 900hp, but didn't race that one much due to the series folding.
Ants, the loaded accountant! Although, 1100 a week after tax isn't really a lot. :/
like I said before for over half my career I was on lots less than that and managed fine. It's also the right around the average wage. That said I don't spend a whole lot on booze or going out ect which can mount up real fast.
Wish I was loaded.......but I'm not. Before I had a mortgage and more importantly a family of my own I was like you Bunta and pretty much laughing all the way to the bank. And that was on almost half the income I am earning today. Now we are on a tighter budget but confortable but only just. Gone are the days were you could just live on one income stream when raising a young family.
Anyways enough of that. I left my wallet at Bunnings (again) and just managed to get it back! I can't be that intelligent to do this three times now!
Once Anna gets a job we will be laughing all the way to the bank. As of now is just comfortable. I am lucky in that at the end of the day I don't need to worry too much about the future so thats good.
Stop leaving your wallet ya silly bugger!
Back when i was a kid, my mum left her purse on the roof of the car on the way to a place on the other side of town. It managed to stay on the roof all the way through town (must have looked a sight!) only to fall off out the other side where the road got up to 100k's. luckily someone who lived there found it and gave it back (minus cash though... but to be fair kids could have found it and stripped it before they did). Certainly wouldn't get that in the city.
Good morning Luke.
$250 to save up for things? That's just if things were to remain the same...... you know thats not going to happen man. But trust me when i say this, when you have a family and own a GTR, EVERYTHING changes and is MUCH more expensive and $1150 will soon feel like $150!
So there you go........now when are we gonna see some baby Luke's :P
250 more then I have at the moment.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
