Nick just tell him to go buy a supra. None of this conversion stuff thanks
I heart conversions, do something different... I hate reading performance imports and the like and seeing the same thing over and over bores the shit out of me
Sweet ;) 6.3, what's he got like a 408 Windsor?
The cousin I was just talking about has an xt ('67) ute and an xb gt 4 door as well... I think he's a drug dealer lol
Other mates got a real clean xc ute with a built auto and ratchet shifter as well as an xr6 turbo
Not sure what it was based off. All I know it's for the effort it does not make near enough power. It's in an au ute. Some company made it for him about 10 years ago. Was in Street machine and was meant to go into production but never did.
I usually do at least 60 hours a week. And then got told in a meeting yesterday that we don't do enough. :/
Unless you are getting over 250k you are not being paid enough for those hours.
I do close to 60 hours a week and I'm on way way way way way less than 250 thousand :(
Not on $250k a year. My salary dropped something chronic in the last 12 months. :(
You know what the problem is, employers will always want their employees to do "more" work for less or the same money, and employees always want to do less work for more money.
My salary is directly proportionate to what I bill so have no issues working longer hours.
If I know I need to leave early one day for a club event or whatever, I'll pull in the hours on other days. But to do this and then be told that we're taking the piss and not putting in the hours is a shit statement to make.
Most people are in here from 8-4:30. Im here from 7:30-8ish through till 7-8pm easily.
I do 5-1 Monday to Wednesday and 5-7 Thursday Friday and work every second Saturday... I never claim my jobs to be overly difficult but anyone who's worked in customer service/retail will tell you how much it can take out of you
Some humans are wankers
I could never do customer service. Even now I have to deal with people way too much.
I guess when there is no job market your lounge of work can be some what problematic
This as well as a few other factors that have been draining on my time has made life extremely frustrating.
Let's just say that my drop in salary is roughly equivalent to a new decent car...
farQ.
I bet if we tallied up the hours you spent on here whilst working that '60hours' a week would suddenly be more like 40 if not less!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
