Because alcoholics like company? Why do you call me an alco?
Those with a sex addiction? Like Michael Douglas
To get hard instead of high?
+1 Mr Ants. The Valley can be a scary place at night. Was totally disgusted to see what looked to be a newborn sleeping on the streets on Friday night.
there is plenty of rules. Just not playing the game right Andy
Rules for chasing women?? Nope. All is fair in Boobs and Bishes
Bish wrangling is a non violent sport. Not allowed to slap the bishes around, they bruise easily
Not allowed to claim point on a mates bish, if you do not know said shooter the bish is fair game and you may claim point.
If the bish is sick or otherwise too incapacitated to know the difference. exercise discretion (would not recommend)
I think you've been an indoors pet for too long. Doesn't seem like there is any rules when the missus brings you your fish on a plate and pets you.
Ahh this just goes to show how little known we are around the place now, I am ok with this.
Keep chants away from Bunta Pony.
now now lets not go nuts!
Yay EKKA sickness.
EKKA sickness? What is this? A general lack of interest in always things Ekka including the shitty traffic or drinking too much then going on the rides?
The mass cold/flu that afflicts Brisbane during the Ekka because all the sick people go and mingle with the healthy people.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
