bit off topic.... Looking at where to go next with the 33. Wanting to go 30/25 but not sure if i want to spend the money to take out my engine put on a 30 bottom end and put it back in. or sell the whole car then build a motor and put in new shell/better. Thoughts?
Makes sense. What's in the unicorn?
hks 2510s with a twist
on the fuel pump topic a stocker will run out of flow at around 200rwk
on the engine topic. Keep an eye on Noels for sale threads. He is always selling dirty 30s
Scott, Talk to Richard he has one already built and up for sale. May be a cheaper option.
I actually thought about this. I seem to remember in passing discussion with him that he mentioned having one "upstairs" couldnt remember if he had said it was for sale or not.... might be worth an enquiry
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
