when thery done the run in tune, I was told it was running 12.6v, and they didn't want to push it.
just checked, is running 13-13.2v.
so, should be all good.
didn't drop under 13.0 for more then half a second.
I wanna go fast.
This is good news
That sounds good. I want to finally give the Gatton sprints a go next year. Have been trying for that one for 7 years to no avail
I want to do Gatton, Leyburn and Noosa sprints next year, depends on timing for other pinny cup stuff though. Will definitely be doing Leyburn again because Mrs family does it every year.
Can't justify it at the moment unfortunately. Tow car/4x4 is higher priority for playing with the 31 next year and I don't drive enough anyway, can't deal with 20k sitting in the garage for 6 days of the week. And then on the weekends I'm playing with the 31 etc so no real point of having one at the moment. All those things and I really want to get an investment property in the next year or 2 so that goes a long way to a deposit etc. Shit happens.
Yeah I loved mine when it was clean, it was just such a bastard to keep it that way. Black will be just as bad but it only shows up dirt badly, won't have to deal with that shitty exhaust stain on the rear bar. When/if I get another one it will be a dark colour. Black or I might try and find a dark blue pearl one.
The Blue is good. I really need to repaint mine. Really not sure what I would go for.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
