Hahah not today boss isn't in for most of the day so I have already finished bulk of work :P
Just going over it all now making sure it's all 120%
He will check when he gets back
1 thing left to do, starter motor in a vz commo
Lucky you! Got a client interviewing a candidate in our office in the city so I'm supervising.
Supervision - lets break this word down
super - something wonderful, fantastic, marvelous, tremendous, great, excellent
vision - dream, hallucination, apparition, idea, visualisation, realisation, revelation, prophecy
For Tony, I am going to choose the ones in the bold for the type of super-vision your currently undertaking :nyaanyaa:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
