Ouch. That sucks bro. Seen some very old links that aren't working any more. Eg: funkymunky's history of SAU thread. Unfortunately none of those links work - they are also about 10 years old...
Yeah the photos i am looking for link back to sauvic which is long gone
Nick did you end up going clubbing
Yer bro went out in toowoomba Saturday night, so much driving happened that day for 2 hours of drags lol.
Was a good night, ended up back at the Westbrook pub kinda early as everything was dead, and then went and hung up side down on play ground equipment lol
I hear ya, 3 hours driving round trip for me, totally worth it.
Haha yep it should be on the lanyards/ business cards lmao
Officer: Do you have a description of the vehicle...
Complaining party: http://www.skylinesa...ttach_id=434803
Officer: I see...
You know...Technically Nick is the only person remotely close to having the right motor in his boat...unless someone has a 350 chev that I am unaware of.
not sure I 100% follow u on that one
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
