ha ha ha but i have poo brown eyes >_<
i can't avoid it!!!!!!!!!!!!
oh, i see now (no pun intended) well, just guage out your eyes, problem solved :P
Just be careful of the other guy's poo on them
nah, lee emptied himself out before hand, and i mean emptied. a hose up there will really do that to you though
ARGH!!!
BASEMENT f**kING JAXX :P>_<
*stab stab stab*
Just take me back to your house!!
your house!
I dont want to go home all alone!
Just Take me back to your house.....
:D dam friggin catchy song.....
4 words:
SOMETHING YOUR NOT GETTING!
:P
Nah you have it all wrong. Shane gets heaps of sex, apparently there are plenty of guys in his area willing to put out... or at least take their teeth out for him
hahah is that so mike >_<
the lightest of lightest wheels (without going magnesium or titanium of course lol)
titanium ftw, thats what i'm after anyway. *looks at price tag and starts to cry*
and marc......*shudders*.........but doesnt he have to pay them? i mean its shane, come on :P
is it that take you back to my house or whatever song?
Indeed
I can't stand it!
lolz
hmmm what about these...
>_<:P
nah titanium isnt cheap is it, when i ordered my rods, i priced the titanium ones, and for a set of 6 they were gonna be US$8250 compared to US$1100 for billet ones :P
:woot::yes:;)
Have you seen the copies of the Rays Volk's?? RAVS VORK's >_<:D
ur joking right? ;)
whats the quality like? :P
Guest
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
