you'll get over your inferiority issues one day john
also, i might be able to help with the x-trails. after all, we do buy them from nissan too ;)
then you need to get out of your parents house more and stop looking on the internet
:D
here are a few groupie photos, more to come lee
Lol, dude i have heaps of random pics of Chicks too....
They only let you take their photos cos they think your a gay hair dresser and dont want to root them, they know if i took their photos i would be sexen them all night lokng :)
its a very big tune lee. the car was only running 6psi before that and now we are connecting up the intercooler as well, so no i am not deluded, i actually know what i'm on about.
They only let you take their photos cos they think your a gay hair dresser and dont want to root them, they know if i took their photos i would be sexen them all night lokng :D
NO! NO! NO! Lee. didnt you notice that hlaf the groupys were male. Just confirms what we always suspected about rotorheads.
dude, pics you downloaded off the net dont count, seriously. and since when is Lihn letting you out of your cage at night? i heard you got in trouble down at the animal pound last time you got let out? something about violating the strays? :)
this coming from a man saying his the turbo on his car doesn't run a wastegate.....
i'm really sure you do, thats why your doing all the work your self... oh wait your not :D
dude 130 to 250 is almost double your figure... so what now your running 30psi???
actually i dont think its that hard to get 200+kw out of a 13BT, only problem is he'll have 0.000000000001nm of torque :)
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
