Ok, why is the old site address linking straight to SAU??? I thought the idea was to leave it read only for a while and then shut it down???
It looks like it has started already... You guys say one thing but do something else... Sounds way too familiar!!! I'm out of here!!!
Hey Nick. Don't take all of this so serious.... I in fact would love to see and go for a drive in your car sometime.
The fact it has an LS1 in it is always gonna cause a stir (especially on here)
Have you thought about what tread you want yet?
Good, only input I've seen since you've been here is whinging anyway. :wave:
Not taking things seriously, stupid Internet lol.
And I duno, I'm gona head down to willowbank this week for the test and tune and see how she hooks up on the stickier surface...
I know it sounds ridiculous because I'm not making huge power but I'm seriously playing powerskid games through first and second and the first hint of a launch.
I guess $100 235/45s will do that :P
Do you really want us to answer that?
What's going on Zac
Nothing much working, taking about cars
Oh yeah nick ls1 umm got a bit of a suggestion. Was talking to someone about cams and springs... Is yours double springed?
you are such a tard. Would you like a jump to conclusions board game as a parting gift?
the web host of the old forums is sh1thouse and i setup a redirect but it seem to redirect "all" http requests. I am working with them to resolve it.
It's still stock cam ATM, its getting a comp cam 232/234 112lsa, better pushrods and valve springs after the drag day. I'm not sure if there double sprung or just heavier spring rate
Yep we are straight up all shit blokes. Should be shot. How is your tin foil hat dave?
http://www.skylinesaustralia.com/forums/topic/424059-voting-on-forum-relocation-to-the-mothersite/#entry6893404
just thinking about cheap tyre options. Like Nankangs and Federal 255/40.
I have a full set of Advan A048 255/40s sitting in my garage as well but want to use for track days (if my car ever gets finished :( )
Better pushrods is an oxymoron.
For tyres I would see what sort of money you can get Federal EVOs for. Or just use the 595s and get them hot, Noel used them back in the day and they performed well after a large burnout! Also Theo Woolett ran a 9 on them in his GTR so they cant be all bad!
But in all seriousness 90/10 shocks is what you really need. When I first upgraded the turbo in my old 32 I had no traction at all, if I went to pass someone on the highway it would put on a smoke show! But i set up my subframe bushed for squat and got the shockies set up to keep the weight down over the rear and the problem was solved.
In fact I wager that even with bigger, better street tyres you wont get much of a result until the suspension is addressed
Edited by Bunta
Same here. Fix brakes and suspension first though.
Are you positively annoyed friend? bro?
Lawl. Take your car against the abomination at drags :P I know that you said you couldn't be there, but I can drive her :P
This. Let's not forget that Ben is doing this for FREE in his OWN spare time. Spare time is time that tends not to be at work, or involved in other activities outside the club (read "shagging waitresses" for benno)
Guest
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
